Re: Original Farmall
Posted by F-Dean on July 18, 2011 at 19:41:00 from (75.241.211.71):
In Reply to: Original Farmall posted by Two Banger on July 17, 2011 at 12:08:14:
The early F-20s had a cast iron steering wheel whick acted like a flywheel. You could just flip it while you were busy raising the cultivator and it would turn itself using the "Automatic" brakes - the cable would brake the wheel in the direction you were turning. After the tractor was turned, you just flipped the cast iton steeting wheel back to staight ahead as you lowered the cultivator.
The more "Modern" steering wheels were too light and made your hands black!
