Farmall 100 Hydraulic fluid in oil
Posted by chad from michigan on July 18, 2011 at 19:50:08 from (67.142.164.27):
Ok after checking into my loader lifting problems and filling it back up wit fluid and changing the oil I used the trator and checked the oil after the loader stopped lifting. well the engine oil smells like tranny fluid and the loader is low on oil. Ok the pump is bad? Can I rebuild the pump? replace it? or what went bad if it is leaking into the engine?
Thanks
Chad
