To part or not to part out farmall MD
Posted by jonnny2006 on July 19, 2011 at 00:15:09 from (66.44.187.48):
I have a 1950 MD and there is a gear in the front of the engine that is not allowing the mag to spin therfor it dosent run... i bought it from a sheriff and it last ran in 09 ran great on diesel and ok on gas acording to him he said i just got it warm enough to switch it to diesel. engine is free. its got charlynn power steering and a M and W 9 speed kit in it. I wanna fix it as it would not take much to get going and i got the right guy to do the job for me he used to work at ih in the repair shop in south mn. he post on here all the time. i know the tractor is worth more parted out then if i fixed it and sold it. the paint is in its work cloths and it has mis match tires but are in ok condition. i know the head is worth big money so is the injector pump and the power steering unit i seen one go close to 1k on ebay. i just hate to reck a good tractor even the lights on it work. the guy said it just died on him and i thought it would be a simple fix turns out a gear that turns the injector pump and mag has stripped out or broke. i really wanted it cause the gas M's are not easy on gas and i love the M and W 9 speed trannys. there not the cable type. i know which gear it is but the prob is im disabled and cant do heavy work. i would like the guy to fix the part for me but parts are getting hard to find. i paid 2220 in 09 it had a bucket on it i took it off to get the front cover off. i just hate to canabalize a good tractor. the mag i had for it had a crack in the housing its special as it turns backwards. i can put a dist on it of a 400 or get a mag from a number of sources. i just dont want it to sit as its a cool tractor and has a plug in heater to boot. what you guys think? i wanna fix it and swap the wide front end off my 50 m as its an orignal ih wide front it would make it a bit more rare. the thing i like about the M and W 9 speed is that in high range it speeds up the pto so i have a back up genny for power and i would not need it to sit there a run wide open when its not called for. the genny is a pto hook up and has a volt meter on it and your to run it between 215v to 225v 60 hertz so i could match the 540 rpm on the high side of the 9 speed save fuel and easy on tractor. (yes i have a double throw saftey switch so i cant feed power back to the grid)if it was summer and i needed more juce i could throw it in low range and run her at 540 rpm in low range. the genny i got will put out 105 amps i dont need nothing near that i only need 12000 watts(used my dads portabal before i got my own) at least in the winter it runs everything summer i would need more or shut off a ac or 2. but i got a 45hp tractor that i could hook up and that would be plenty just hate to leave a gas engine run wide open when there is low load. plus the md would be cool for wagon rides as 5th on my h or super h is to fast and lugs the engine at low speeds and 4th is too slow unless you wanna burn almost 2 gallons an hour,and loud im not putting the bucket back on it as its a trip bucket and my super c has all hydro and is a fuel sipper and quiet. sorry for the long post. i will call you about the tractor and what i or we decide to do with it i just dont want it to sit no more....... i dint wanna mention your name but ill call you tommorow, i know its very hott out. thanks for all comments good or bad john. i know that 45 hp wont produce 105 amp but it will get me about 80amp constant 100 peak i know it takes 1.8 hp to get 1000 watts 100 amp = 110,000 watts to 120,000 watts depending on if your getting 110v or 120v at night time volts usually go up on the grid as there isent such a huge load straing the system.
