There are several options for mounting the rear wheels on a B. Depending on the tire size, you should be able to get the width well below 83 inches. If I remember correctly, the bolts that hold the rim to the wheel centers are 5/8 so that would make the nuts 7/8 or 15/16? I'm not sure, but if they are original they may have square nuts on them.
My B is about 78 inches wide, outside of rim to outside of rim. Of course the centers will be wider, but that should be above the height of your trailer fenders.
I haul my B on a trailer that is about 83 inches between the fenders. The wheel weights ride well above the trailer fenders.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
