Re: Narrow the wheels on a farmall B?
Posted by gene bender on July 19, 2011 at 09:45:37 from (207.177.56.53):
In Reply to: Narrow the wheels on a farmall B? posted by chevy_cowboy on July 19, 2011 at 06:33:05:
It will depend on two things. First what size are the tires. The 9.5 on the 8in rim mite clear the final drive. Some final drives do have a grouve cut so the rim can be set in the extreme in position. IF and a BIG IF the tire size is 11.2 or larger forget it. I have several As and Bs so im not giving bad advise having been thru it several times with the different combinations of setting the rims. I have some tractors with 9.5s and they are set in the extreme position and some tractors dont have the grouve. Now the 8.3 on the 7in rims no problem. So you will need to see which tires and rims you have. If the rims are wider than 8in measuring 9in overall you cannot move to the narrow position.
