Other than the comp ratio of heads could be different, the ignition systems have several different spark advances. Magneto was basically 35 degrees , batt ign could be 40 ,30, 25, 22, or 16 so that would be one place I would check out. Some minor changes were made in carburetors, main jet size, air bleed size or blocked air bleed on some power packs. Valve length will tell you which head you have but of course you can't tell that without disassambly. You could check the head numbers under valve cover. A worn out govenor will make a gutless wonder also along with the proper adjustment of govenor internal linkage.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
