A sticking pressure regulator valve could be the problem but it should not be affected by RPM since it should have a constant 3 GPM flow. A sticking flow divider valve could cause the oil flow to drop with the lower engine RPMs but there again if you are getting less than adequate flow to the controls the pressure regulator valve, trying to maintain pressure, should close off all flow to the lube circuit causing the lube light to come on.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
