Posted by Owen Aaland on July 19, 2011 at 16:34:24 from (216.47.34.189):
In Reply to: IH 966 PTO issues posted by Andi on July 19, 2011 at 06:47:06:
Do you mean you have a remote mounted, PTO driven hydraulic pump for the loader? The PTO is not remote mounted on the tractor.
It is possible that the oil pickup tube for the PTO has come out of place or the tube seal is leaking. To check it face the tractor uphill so that you have extra oil covering the PTO and see if the problem is still there. The normal full mark on the oil dip stick will put the put level at the middle of the PTO drive shaft. The pickup tube is just below the drive shaft so if the oil is a little low the seal may be above the oil level. If the tractor is facing down hill the seal and top of the tube will be above the oil level.
Another possibility is internal leaks in the PTO assembly, either the piston seal, or a worn housing where the sealing rings ride.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
