Re: 706 PTO SEAL
Posted by Owen Aaland on July 20, 2011 at 02:15:24 from (216.47.34.189):
In Reply to: 706 PTO SEAL posted by dusty britches on July 19, 2011 at 21:20:52:
The 1000 RPM shaft seal can be replaced without dismantling the PTO assembly. The 540 shaft seal is installed from the inside of the rear casting so complete disassembly of the PTO unit is required for that one. However there is an aftermarket seal kit for the for the 540 shaft that uses the existing threads in the casting to attach a seal on the outside that may work. Part number 830470 from Hy-Capacity.
This post was edited by Owen Aaland at 02:16:12 07/20/11.
