Re: H belly pump delete cover
Posted by rustyfarmall on July 20, 2011 at 04:58:18 from (216.248.71.224):
In Reply to: H belly pump delete cover posted by DanR on July 20, 2011 at 04:16:25:
It is not just a piece of sheet metal. The original cover is made of cast iron and is maybe 3/8" thick or even thicker.
It is my opinion that either the belly pump or the delete cover needs to be in place to maintain the structural integrity and strength of the clutch housing.
