Re: priming w450
Posted by Brownie 450 on July 20, 2011 at 07:50:02 from (66.43.241.198):
In Reply to: priming w450 posted by dusty britches on July 19, 2011 at 20:54:24:
It will help to have a full tank of fuel. Make sure you have the main supply on under the tank. Proceed to vent out each fuel filter until fuel is running without air bubbles. You should start the engine on gas & let run until the pressure gauge on the injection pump shows pressure build-up. At this point, you should be able to switch over to Diesel.
You may have to loosen [bleed] the bleeder screws at each injector to check for fuel being delivered.
Good luck.
