Yes, the oil pressure gauge is in the correct spot. You are also correct in assuming that those tractors don't have a water temp gauge. They should operate at somewhere around 175-200 degrees, however. There is also no water pump on your tractor (I actually don't think there are water pumps on any offset Farmalls). Coolant is circulated by "thermosyphon". It operates on the principle of "heat rises and cold sinks", and is pretty efficient, with the main benefit being that there is one less item to break.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
