Re: Some Farmall B questions
Posted by athol carr on July 20, 2011 at 15:11:28 from (115.188.3.223):
In Reply to: Some Farmall B questions posted by chevy_cowboy on July 20, 2011 at 12:01:23:
THe original 1939 and 1940 tractors had no provision for a starter. In later tractors it was always and option. There is no water pump, thermo-syphon cooling was used. If the original tractor was for kerosene or distillate fuel there would be a starter tank for gasoline (extra hole in the hood opposite the exhaust pipe hole) and the tractor would have radiator shutters and there would also be a temperature gauge. If it was a gasoline tractor then the temperature gauge and shutters were optional and most would not get them. The temperature sender was fitted to the top if the water inlet from the bottom of the radiator to the bottom of the block and the gauge was positioned above the governor unit. The oil pressure gauge is located at the bottom of the oil filter. The oil coming from the brake rod housing sound like the seal between the transmission and the brake housing is leaking and this would require removing the reduction gear housing and axle from that side of the tractor. Heavy but can be done.
