Re: farmall B
Posted by gene bender on July 21, 2011 at 04:09:55 from (207.177.56.53):
In Reply to: farmall B posted by Jim Iowa on July 20, 2011 at 20:47:23:
None you will need a plate to block off the hole where the hy pump fits. New sleeves and pistons can be had for 54 a hole then you know what you have for an engine. Used engines can have problems too. If you swap out engines the Bs block is worth some good money. So is the head dont sell for scrap.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
