Yes, without knowing what exactly you have, nobody can tell you exactly what you need. I'm gonna assume you have a stock tractor with no 2-way valve.
It's really pretty simple once you've seen it. People always think hydraulics are this mysterious complicated thing...
To get down pressure, you need a 2-way open center hydraulic valve of some sort. Originally the tractor would be equipped with the optional 2-way "christmas tree" valve mounted on the right side behind the hydraulic block.
You can use any commercially-available 2-way open center hydraulic valve. When shopping look for one with NPT ports, so you don't have to mess with adapters. Mount the valve somewhere convenient.
There are two pressure ports on the rear of the H hydraulic block. Cap one off and run a hose from the other to the IN port on the valve. Run another hose from the OUT port on the valve to one of the drain plugs on the hydraulic block.
Run a hose from one work port on the valve to the rear of the tractor. Install a TEE fitting on the end of the hose. Run two short hoses from the TEE to the SAME END of both hydraulic cylinders.
Do the same for the other work port to the other end of the cylinders.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
