Re: Removing Gas Tank from IH 350 U
Posted by big fred on July 21, 2011 at 10:37:35 from (130.76.32.215):
In Reply to: Removing Gas Tank from IH 350 U posted by Chris Schlossnagel on July 19, 2011 at 20:04:29:
Toughest part of removing the tank on my 300U was getting at the cotter pin on the bottom end of the throttle shaft. Tough to get big hands in there. Other than that, you might find that removing the steering wheel is difficult due to rust. You'll need to remove the wheel and unhook the throttle shaft to get the dash out of the way.
