Re: 47 M Farmall / Weak Starting
Posted by kevinj54 on July 21, 2011 at 11:03:27 from (99.39.189.166):
In Reply to: 47 M Farmall / Weak Starting posted by Ken Ind. on July 21, 2011 at 10:59:40:
You say NEG ground, these are POS ground, probably don't mater much to the starter though.
Are the connections all REAL clean???
What size are these "heavy duty" cables?
What is voltage while cranking?
Unless your starter shop has a way to test under load the starter may still be in poor shape
This post was edited by kevinj54 at 11:04:45 07/21/11.
