Re: 47 M Farmall / Weak Starting
Posted by glennster on July 21, 2011 at 11:40:48 from (76.223.246.119):
In Reply to: 47 M Farmall / Weak Starting posted by Mayor on July 21, 2011 at 10:59:40:
try moving the ground cable for the battery directly to one of the starter mounting bolts instead of the tractor chassis. my 48 m was always a slow cranker, everything was replaced new and heavy duty, still cranked slow. moving the ground was the solution. i kind of think that corrosion, grease and oil gives a bad connection over all the years.
