Re: Is there any reason
Posted by gene bender on July 21, 2011 at 11:54:57 from (207.177.56.53):
In Reply to: Is there any reason posted by Kevin W on July 21, 2011 at 11:03:03:
Adding second set of lites will cause more amp draw that your system is set for. Now if your gen is the original and you have the adjustable thrid brush you can increase the amps with no problem. You wont be using the lites all nite long anyway. You can check the gen and look for the screw head on the brush end and remove the brush cover to see how close the third brush is and adjust accordingly. Mite need to take the gen to have it serviced.
