Re: 47 M Farmall / Weak Starting
Posted by kevinj54 on July 21, 2011 at 11:57:07 from (99.39.189.166):
In Reply to: 47 M Farmall / Weak Starting posted by Janicholson on July 21, 2011 at 10:59:40:
Good idea, I have to do that to mine someday.
I loosened and torqued some of the bolts before I painted and all has been well.
One can check with a volt meter and find the poor connections easy enough.
