Re: 47 M Farmall / Weak Starting
Posted by gene bender on July 21, 2011 at 12:01:07 from (207.177.56.53):
In Reply to: 47 M Farmall / Weak Starting posted by Mayor on July 21, 2011 at 10:59:40:
There must be a bad connection somewhere. If the ground cable is long enough attach it to one of the mounting bolts on the starter. A good system sure will start theM on 6v. Ours even started after the FireCrater kit. That was in 62 and the tractor was new in 49 same starter.
