Re: 100 hyd update
Posted by Daniel H. on July 21, 2011 at 12:02:38 from (66.226.46.71):
In Reply to: 100 hyd update posted by chad from michigan on July 20, 2011 at 09:51:49:
Don't forget the gasket between the pump and the block, and if the shaft on the pump has a groove from where the seal rides you will need a speedi-sleeve, otherwise the new seal will fail.
