Re: Janicholson, would liketo ask you.......
Posted by old on July 21, 2011 at 14:05:04 from (209.86.226.59):
In Reply to: Re: Janicholson, would liketo ask you....... posted by ArloInt on July 21, 2011 at 11:54:21:
A tractor with a 12 volt battery and no charging system or one that does not work like it should will run one for a very long time. Plus if the battery is a newer one and in very good shape it will sort of recharge it's self when not being used. I have one tractor that had a bad alternator on it and I ran it that way for years and only about every 4 month did I need to charge up the battery. That said in the long run it is cheaper to use an alternator like the Delco 10si then to go with a new generator system
