Re: 240 Farmall not running
Posted by El Toro on July 21, 2011 at 14:26:53 from (108.15.86.54):
In Reply to: 240 Farmall not running posted by luke101 on July 21, 2011 at 13:55:21:
You need to pull off a plug wire and have a helper try to start the engine while you hold the plug wire about 1/4 inch away from the sparkplug. Make sure the ignition switch is in the on position. If there's no fire you need to use a test lite or volt meter to see if battery voltage is getting to your coil. With the points open and the ignition switch in the on position you should have battery voltage on both small terminals on your coil. If you have battery voltage clean those points with some 320 wet or dry until shiny then see if the engine will start. Hal
