Re: Janicholson, would liketo ask you.......
Posted by IH fan on July 21, 2011 at 16:29:22 from (99.151.34.87):
In Reply to: Janicholson, would liketo ask you....... posted by ArloInt on July 21, 2011 at 11:09:13:
My 240U had been changed to a 12v system with a one wire alternator and no VR. It charges okay, but my problem was with the starter. The problem is the 6v. starter would spin too fast before engaging the ring on the flywheel. This caused it to chew up the starter gear and to a lesser extent, the flywheel ring gear. When the starter finally quit and I had it re-built, the mechanic replaced the field coil in the starter with a 12v. coil.... never worked better than it does now.
