Re: 47 M Farmall / Weak Starting
Posted by Mayor on July 21, 2011 at 21:58:05 from (174.53.69.134):
In Reply to: 47 M Farmall / Weak Starting posted by Mayor on July 21, 2011 at 10:59:40:
Oops...meant pos. ground.
Anyway....after all day in this heat....I traced it down too a short in the battery. It was showing 6.4 volts but a trip too Napa and putting it on they're tester showed up a short in the battery under load. 105 bucks later for a new commercial duty 6 volt battery and we're starting just fine now!.
Dont always trust your battery even though the voltage is showing O.K.!
Thanks for all the replies!.....Its nice too know there is help too keep these ole girls up and running!.
