If you have the transmission driven PTO without TA most likely you are going to have to install the PTO drive line from the clutch pressure plate all the way back to the PTO assembly. If you have a TA assembly then you may be able to get by with just replacing the PTO assembly in the rear and replacing the pressure plate cover, the TA input shaft, and adding the IPTO gear in the front of the clutch housing. Either way it is not going to be a simple PTO swap.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
