Re: Janicholson, would liketo ask you.......
Posted by Janicholson on July 22, 2011 at 07:06:02 from (199.17.6.36):
In Reply to: Re: Janicholson, would liketo ask you....... posted by Owen Aaland on July 22, 2011 at 06:11:47:
with respect. The impulse coupling allows it to make spark at near 0 rpm. Hand cranking (in almost every case) will not produce a spark W/O an impulse in operation. A mag used as a distributor with a defective impulse will break your arm. A mag with hand retard mechanism (early IH and others) will spark at the advanced setting making kickback. a impulse based mag with timing retard built in when the timing is set wrong, will do it as well. Jim.
