Re: 240 Farmall not running
Posted by rustred on July 22, 2011 at 11:45:15 from (72.172.100.113):
In Reply to: 240 Farmall not running posted by luke101 on July 21, 2011 at 13:55:21:
any engines that sit over time usually require the points to be cleaned espesially if they are in the closed position. they build up corrosion , so either file them, replace them or what works for you. experiensed many many engines like this. but ya lube cyls. also as its part of the get running procedure.check and clean fuel system as required also.
