we always ran our return lines from the shaver post pounder right into the transmission/hydraulic fill hole. I don"t think you will get good results if you do it the way you suggest. on your 656 the top and bottom remotes are both pressure and return, depending on which way you push the remote control lever. You should have plenty tractor to handle that driver.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
