Re: missing at half trottle
Posted by Janicholson on July 24, 2011 at 10:44:28 from (199.17.6.66):
In Reply to: missing at half trottle posted by uglyjim on July 24, 2011 at 07:47:01:
On some tractors the sound of a leaking valve, and associated misfire can be detected only at certain speeds. A leakdown check would detect the issue, but requires removal of the injectors. A compression check is the same. I would adjust the valves (looking for a tight clearance on one valve.)
I would also crack the injector lines one at a time to find the misfire (assumes it does it in neutral sitting in the yard)
Exhaust manifold temperature analysis (with a infrared hand held) might also be decisive in locating which cylinder is missing. Good luck, Jim
