Re: 1930 Farmall Regular Exhaust/Intake Manifold Studs
Posted by russ/ks on July 24, 2011 at 11:09:30 from (75.107.19.159):
In Reply to: 1930 Farmall Regular Exhaust/Intake Manifold Studs posted by Stevie J. Mote on July 24, 2011 at 08:57:48:
Hello, Stevie, still planning on e-mailing you back. Studs are used on McCormick- Deering tractors of that vintage as the holes go into the water jackets. Bolts threaded in are tougher to seal off, but it can be done with thread tape. I try to use studs. I can measure a manifold and tell you how long they need be, may be able to have a local machinist make you some.
