Re: Gear oil leaking from M brake housing
Posted by The Red on August 12, 2000 at 07:20:03 from (12.75.196.44):
In Reply to: Gear oil leaking from M brake housing posted by Lowell on August 12, 2000 at 07:15:44:
Lowell your bull cage seals behind each brake drum are worn. You will need two seals per side for replacement. The original double seal is about 1 inch thick. The new single seals are about 3/8 inch thick.
Post A Followup
: Re: Re: Gear oil leaking from M brake housing
