Oil Pressure Fluctuation
Posted by Johnny Upstate on July 24, 2011 at 18:41:06 from (50.48.18.156):
When I first start the Farmall 230 the oil pressure gauge works properly with the needle moving about 2/3 to the right. After running for about 45 min the pressure gauge drops way down and the needle becomes very erratic. The oil level is full and engine seems to be running ok. I have changed the gauge but the problem persists. Any thoughts on what might be wrong? A local mechanic suggests it might be the oil pump. Thanks for your help.
