Re: Oil pump rebuild - Farmall H
Posted by rustyfarmall on July 25, 2011 at 12:26:53 from (216.248.71.224):
In Reply to: Oil pump rebuild - Farmall H posted by Yooper Farmall on July 25, 2011 at 12:09:16:
Usually what happens is that the gears wear into the bottom cover and/or the bottom cover becomes warped. The cure is to make that cover flat and true again. Some folks place a sheet of emery cloth on a plate of glass and then work the cover in a circular fashion around and around on the emery cloth untill it is flat and true again. Another method is to take it to a machine shop and have it either milled or surface ground.
The one I fixed was so worn that I quickly gave up on the emery cloth trick and instead secured it in a vise and used a large, flat file to "mill" it flat. I know it sounds rather crude, but poor people have poor ways and it worked. I even made my own new gasket, but it would have been better to visit Case-IH and buy one.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
