Posted by chris706 on July 25, 2011 at 18:21:55 from (12.54.169.194):
In Reply to: Re: MCV Issues posted by Owen Aaland on July 25, 2011 at 14:48:27:
The pressure was only checked at ¼ throttle at the most and T/A lever forward. I will check this weekend with the T/A in both positions and a little more throttle to see if the pressure changes. I will also shift the T/A and observe the pressure for change. I changed the brake valve because the old valve had a broken shaft where it attaches to the brake pedal. I adjusted the brakes per the manual for linkage adjustments. Prior to the adjustment the brake on the right side was dragging, because when you let the clutch out the wheel would act like it was dragging for a second and the tractor did not want to roll freely. One thing I have noticed is the left brake drum feels very warm after driving a distance. The right is cool. I have never removed the MCV valve from the tractor. The one thing that I did to the MCV valve is I disconnected the linkage from the T/A piston and removed the piston to install a new O’ring to repair a leak. That piston stops against the snap ring. Where is this orfice that you described in the brake valve or brake line? Could that piece be missing? I am only going with what the salvage yard told me on the brake valve. It looked a little different, but not much. It bolted right up the same.
Could I have the Power steering lines crossed? I hooked them up per the manual.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
