Re: 1950 farmall super w-6
Posted by LaBoyteaux on July 25, 2011 at 21:11:04 from (76.14.94.14):
In Reply to: Re: 1950 farmall super w-6 posted by matt beckner on July 25, 2011 at 20:44:00:
Once you get the tank off probably a trip to the radiator shop to
soak in their dunk tank. Then there is a process to epoxy the inside of the tank (requires an acid wash first I think). Then primer and new paint the outside of the tank. Then the tractor will look kinda silly until you paint the whole thing. If the tank was that bad, the sediment bowl, fuel line and carburator will likely be gunked up too. Carburator cleaner may do it but I've had best luck cleaning the cast parts in a blasting cabinet. Figure on new gaskets all around. Remember there is a small brass screen in the float bowl inlet which is often clogged up.
