Re: Woods Mower on Super A
Posted by El Toro on July 26, 2011 at 05:45:06 from (108.15.86.54):
In Reply to: Woods Mower on Super A posted by DelMN on July 26, 2011 at 05:18:29:
You should call your local Woods Mower dealer. They would probably know if there's a kit available to make the change. You will probably need the model number of the mower on the Cub. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
