Posted by TDEdozerman on July 26, 2011 at 13:46:26 from (209.252.247.34):
Hello all, I am working on a TD24-TDE dozer serial number 3931 water pump and I am having no luck finding parts for it. Does anyone know of a source or have these parts? 250649R3 gasket 257304R91 seal 255114R1 snap ring ST207 bearing 257305R1 shaft ST246 bearing 257307R1 spacer 257309R3 gasket 257310R91 seal 264977R91 seal kit Thanks in advance for your help
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
