Seen a few early ones collapse the pushrod...might be the source of the noise. As for the injection pump, a sticking metering valve can cause the same issue you are having. Sounds like a reman pump is maybe in your future.
I'd lash the valves, and check for a worn cam lobe while you have things apart. Seen a DT414 work rod bolts loose s few times...and had one come apart on me. No more disgusting feeling than sitting in a hayfield, with the smell of hot oil and the tick of cooling metal.....
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
