Re: Need Help!
Posted by JRSutton on July 27, 2011 at 06:20:39 from (75.130.109.233):
In Reply to: Re: Need Help! posted by ScottyHOMEy on July 26, 2011 at 21:30:08:
Shouldn't need saying, but...
Be DAMN sure the engine can't fire while you're hand cranking, and turning it back and forth using the fan belt!
After working on a tractor trying to get it started, it can be easy to forget you have the kill switch open, etc.
If you just remove all your plugs, it's much easier to hand crank, and infinitely safer!
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
