Posted by JRSutton on July 27, 2011 at 14:49:36 from (75.130.109.233):
In Reply to: Super C steering posted by Dodge2500 on July 27, 2011 at 13:55:22:
oh - and by bearings, are you referring to the brass bushings? (the long pressed in brass sleeves)
If it's the bushings you're referring to, those can be impossible to push/pull out.
They're slightly less impossible to cut out with a good chisel.
I've found that carefully hack-sawing them down the entire length of the inside of the bushing works best. Work slowly and methodically and you'l cut through it in no time.
... ok, so I'm not so careful and I use a sawzall.
Point is - cutting the bushing will make it MUCH easier to remove with a chisel.
Doing two cuts will make it fall out on its own.
If you nick the casting a bit here and there, it's really not going to matter. Just go easy.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
