Posted by CNKS on July 27, 2011 at 16:38:20 from (216.144.104.128):
In Reply to: Re: Hytran posted by rustred on July 27, 2011 at 16:01:41:
It may not make any difference, but I need to fix some leaks and would like to try a heavier oil. The clutch is new, everything except the clutch clearance, including the TA, is correct. I did all this about 3 years ago was unable to fix the problem. I still do not have an answer to my question, but I knew a bunch of other stuff would be thrown in.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
