Re: Generator voltage problem
Posted by gene bender on July 27, 2011 at 17:07:03 from (207.177.56.53):
In Reply to: Generator voltage problem posted by Ed Flywheeler on July 27, 2011 at 14:49:18:
Where did you get the regulator and what is the # on the generator. They do list two regs for the Farmalls in that era. Maybe you should move the third brush a little closer this will make more amps. At least we know the gen is OK. If you ground the field what happens to voltage and amps what readings do you get with field grounded.
