Posted by Dodge2500 on July 27, 2011 at 17:19:48 from (99.197.130.250):
In Reply to: Super C steering posted by Kevin B from Illinois on July 27, 2011 at 14:27:42:
It's got a sickle bar mower mounted on the back already, and it's still hard to turn.
JRSutton-
There's a bearing (ball type) at the top and bottom of the shaft that the gear is mounted on. According to the CIH parts catalog, there's only a bushing at the very bottom. I can't get the "washer" off the top of the shaft to begin removing the top bearing, gear, and lower bearing. Seems like cutting it off may be the only option.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
