Re: Hytran
Posted by CNKS on July 28, 2011 at 05:42:28 from (216.144.104.128):
In Reply to: Re: Hytran posted by RPM1941 on July 27, 2011 at 19:34:10:
My point is, I think my current oil is straight 10W. There are some mulitivis generics but I don't think mine is. IF it is 10W, then it gets thinner and causes gear clash as it warms up. It shifts fine when cold. Multivis, particularly if it is 10w30 gets THICKER as it warms up. So, the gear clash should be reduced. I won't know until I try it. Not sure I want to shell out $160 for 10 gal Hytran right now, as I won't need the tractor for a while. You are correct that the 460 era tractors can use about anything IF everything is working right, which my 460 isn't. Also HyTran will hold 1% water. That doesn't sound like much, but it probably helps.
