Re: Super A tune up
Posted by rustyfarmall on July 28, 2011 at 06:49:09 from (216.248.71.224):
In Reply to: Super A tune up posted by Goodman on July 28, 2011 at 05:44:13:
The upper adjustment screw is the air/fuel idle mixture.
Bottom screw is for adjusting how much, or how little gasoline can actually get into the engine. I don't have the specs handy, but I would think that bottom screw should be turned in until it seats, then turned out maybe 2 full turns. The number of turns out will be determined by how the tractor is used. If it needs full power most of the time, that screw might need to be turned out even further. If you just putter around, 2 turns should be sufficient, or maybe even less.
