Re: Good ole farmer mechanics!
Posted by Nebraska Cowman on July 28, 2011 at 15:24:49 from (66.252.126.38):
In Reply to: Good ole farmer mechanics! posted by oldtanker on July 28, 2011 at 11:09:21:
Here is one example. On my Farmall 656 the steering
arm got so I could not keep it tight on the shaft. I
tried re-keying it and it helped for a year or two.
The keyway in BOTH the shaft and the arm were worn.
So I welded it solid. What did I loose? Except that
when somebody else wants it fixed "right" THEY are
going to have to buy the parts and not me.
