Farmall 656 Hydraulics
Posted by Frmldon on July 28, 2011 at 16:53:18 from (64.198.86.192):
I have a Farmlall 656 gear drive and the hydraulics off the auxillary valves are extremely slow. The 3-point and steering both work well. I checked the pressure relief valve by the auxillary valves, borrowing one from another tractor and that seems fine. When I turn the steering wheel with the tractor off, the wheels don't turn, though the steering wheel turns with no issue. Does this point to the flow control valve, as the hydrualics in this tractor drive the power steering first and auxillaries second? Is there anyway to test this, is there something else I should check? Oil level is correct and a newer filter. Any pointers are sure appreciated.
