Re: Hytran
Posted by pete 23 on July 28, 2011 at 18:09:30 from (74.32.234.149):
In Reply to: Hytran posted by CNKS on July 27, 2011 at 14:56:35:
Something else one has to consider in oil viscosity is the range of any given number. A 10W has to fall within a given range when measured at specific temp. W stands for winter so it means the flow is tested at a low temp. Not sure if it is zero degrees f or 32 degrees f. The range can be quite wide so some 10 weight oils may be very close to a 5 weight oil and some may be very close to a 20 weight oil but they are within the specified range for 10. That is also why a 10W 30 oil may be thinner at operating temp than a straight 30 or even visversa, thicker. All depends on the base stock it started at and the viscosity index improvers etc that are added during blending. It is measured in time it takes for a given amount of oil to flow through a specific sized orfice.
